Rearwheelin
Yes or no . Rearwheelin is full of $hit haha.....(like) for yes
I have a couple of those aluminum brazing sticks . I have not used one yet but will now as I think its the best way. The hole for the oil pickup is right at the biggest part of the clutch so oil should hit the hole with a-lot of force. There is not a lot of room for any intruding barbs so I'm keeping the mods outside the clutch cover .Any tips on how I should do this Tinken ? JB weld has a 3960 PSI holding strength. I think Its triple for brazing stick.I heated my clutch cover well beyond the brazing rod and it didn't warp.![]()
I altered you post slightly - before people contacted me about it. I fully realize you meant nothing bad, and I hope you can understand.why not just properly weld the damn thing ?? all this half assed JB weld stuff? better yet, zip-ty used to have some seriously cool cooler set up for the 450, 510, am sure he could set you up with some bits and pieces that would work right , first time out.
The cover is magnesiumwhy not just properly weld the damn thing ?? all this half assed JB weld stuff? better yet, zip-ty used to have some seriously cool cooler set up for the 450, 510, am sure he could set you up with some bits and pieces that would work right , first time out.
Sort of worried about warping the cover when heating it up that hot...
)It will warp if welded.
Will it matter if the cover is out of round a little bit? (little bit = 0.05-0.4mm)
Would it warp at all if the welding was done to the outside while the case is still firmly bolted up?
Yes, I built a oil cooler and it was successful enough to have Husqvarna contact me. But, this is Randy's project/experiment. I suggested brazing because it fell within his means for the prototype and should work perfectly for this application.why not just properly weld the damn thing ?? all this half assed JB weld stuff? better yet, zip-ty used to have some seriously cool cooler set up for the 450, 510, am sure he could set you up with some bits and pieces that would work right , first time out.
Proof is in the pudding; whatever flavor, I hope it tastes delicious!It's not going to warp with a propane torch.Will pre-heating the cover under the oven broiler minimize warping ?
