WHITEROCKET5.9
i have a txc now but im thinkin the next one will be a te model with the txc or similar "racier" suspension setup...best of both worlds i hope
The CTS chassis that centralizes mass and magically absorbs any size bump with zero torque reaction due to the concentric countershaft/swingarm pivot is exclusive to the 449/511, as is the electric engine response that allows you to ride for hours without having your arms turned into wet noodles from absorbing the cammier torque output of the 510 engine.Ewww...I am not looking for a bike like a crf/yzf/kx.....how is it like those??
Next question....does the TXC has a lighting coil....how hard is it to add lights?
From comparing on the Husky website the Transmission on the 2012 TXC and TE models are the same...is this true of the 2011
Also...if the engines are the same, why and how does the TXC have a larger oil capacity....TXC 1.27 quarts and the TE 1.04 quarts???
How is the skid plate on the TXC....is it beefy enough or would you spring for a better one for someone in rocky terrain??
