What's the shop's name?
Just got off the phone with my local shop. He confirmed that it was 15w-50. The shop that originally recommended it was Hall's. They had found that in the 310, it offered a little better scuff protection. He also stated that most of the bearings in that motor/transmission are open caged (a few around the valves and cam lobe are not open caged).
Why does that scare you?I didn't research prices too much. Basically the first one I saw I went with. The only one my local Wal-Mart carries is the Rotella T6, but the 14.2 cSt at 100 C scares me
I bought my 2012 TE250 from Halls and they did recommend Spectro 15W-50.
Spectro Platinum SX4 15W-50
at 100 C = 17.2 cSt.
at 40 C = 138 cSt.
$12/qt
Castrol Power 1 Racing 4T 10W-50
at 100 C = 17.
at 40 C = 110.
$8/qt
Mobil 1 5W-50
at 100 C = 17.5 cSt.
at 40 C = 108 cSt.
$9/qt
Mobil 1 15W-50
at 100 C = 18 cSt.
at 40 C = 125 cSt.
$8/qt
Shell Rotella T6 5W-40
at 100 C = 14.2 cSt.
at 40 C = 87 cst.
$6/qt
I didn't research prices too much. Basically the first one I saw I went with. The only one my local Wal-Mart carries is the Rotella T6, but the 14.2 cSt at 100 C scares me so I think I'll probably go with Mobil 1 5W-50.
Can someone tell me what the different abbreviations mean and which ones are important for a Husky TE250? I see that Mobil 1 is API SN, SM, SL, SJ and ACEA A3/B3, A3/B4 and has a quality level of API CF, but I have no idea what all that means.
Where did you find the Mobil 1 5W50? My local distributor says they can't get it.
*edit to add Castrol
Mike-AK
17 down to 14 seems significant. I think I saw earlier where you said 1 cSt isn't a big deal but 7 definitely is, and 4 is more than 1 and getting close to 7. If 17 cSt is producing good pressure maybe 14 wouldn't be? The unknown is scary
