Mike-AK
17.19 at best would be at the very bottom of the 50W range at 100c. What is "plasti-guage"?I haven't quoted anything that is 40 weight.
Plasti-gage is a wax like material that engine designers/builders lay across bearing surfaces in order to determine separation gauge thickness.17.19 at best would be at the very bottom of the 50W range at 100c. What is "plasti-guage"?
Husqvarna chose Castrol Power 1 Racing 4T 10W-50 as a match to their gauge specifications, but +/- 1 cSt isn't going to make any difference, +7 is a big difference.So where do you find an oil that matches the "plasti-guage" for the TE310?
Strange... The product data sheet and the MSDS for the castrol 10w50 show different viscosities.
No, there's no rush.So, should I be getting the big bore oil (below) out of my 310 ASAP???
Motul 7100 4T 10W60
Viscosity at 40°C (104°F) ASTM D445 156.1 mm2/s
Viscosity at 100°C (212°F) ASTM D445 24.0 mm2/s
People race these engines with this high viscosity oil all the time, but the key word is race and usually don't care if they get more than 1-2 years out of the engines knowing they are going to replace them anyway. Racers run thicker oils in order to keep oil pressure high at elevated temperatures.
Also another reason behind running these grades is because many people are under the impression that the higher shear strengths yield higher bearing separation. This is false. Higher bearing separation is obtained from higher flow. Because oil pressure and flow are inversely proportionate to each other, the higher viscosity while providing higher pressures will yield lower flow rates. This in turn lowers the bearing separation. Lower flow rates also lower the cooling of bearing surfaces. Engine manufactures are well aware of this and balance flow with pressure when recommending specifications.
SN rated too, which you don't see often. I think OHR said he ran his bike for 65 miles without water while running that oil. I think he should get paid to run one of those infomercials...Unfortunately Amsoil Dominator is loaded with friction modifiers and is not recommended for wet clutch use. It looks like the Mobil 1 15W50 is SM rated, so it should be good to go for motorcycle use, yes?
Ask 100 people and you will get 100 answers on Oil !!!
