X lite motor
Well, that's SAE 40W and it's closer to 85W actually. Not sure where 0W40 would actually fit in since it is very thin at cool temperatures. Still to prove your point, it is not only safe, it's better for transmissions than a thicker viscosity.
What year are the drain back kits for ? thx
This kit allows the disconnection of the inconvienent and dangerous drain hose on 2011-12 Husqvarna TE/TXC 250/310s. Reconnection is now convienent, rerouting to the oil fill plug. This kit includes a new drain plug which allows the continued use of the oil prefilter screen, a new oil fill plug with a specialized 90° swiveling hose fitting.
*Note: This kit can be used on 2013-2014 Husqvarna TE/TXC 250/310s for re-routing the lower hose up to the top fill cap.
Tinken, I have a dumb question for you. My bike has the power up and the tech who installed it said it didn't need the map button as it was a 2013 model. I wonder what map is in there and have a call in to find out. I trail ride; never race. What map should I have?
There is a map selector switch, plugs in under the head light. It is not necessary for you to have one. I would load the LeoVince map and add a pc5 when they become available.
