If you are in Europe, look for Shell Helix 0W40 & 5W40 (5w40 is actually thinner).
http://www.wolterwasserbillig.de/fileadmin/user_upload/Formulare/Shell_Helix_Ultra_5W-40.pdf
The thinner oil offers higher protection in a drive train because of flow. I do recommend you staying with the Petronas if it is cheaper.
If you compare the syntium 3000 with shell helix 0W40, I believe you will see they share the same viscosity @100°C.
http://www.mymesra.com.my/microsite/lubricants/pdf/Passenger/Passenger_Syntium3000SM.pdf
No, completely different additive package to compete with M1 0W40, extremely heavy detergents to pass SN ratings.Isn't Helix rebranded Rotella with slight modifications to the additive package? I could have sworn I saw adverts a while back that they were the same - at least the same base stock group.
I actually explained this a little better in my oil thread in my forum, but looking at shear is something we used to be concerned with conventional oils when working with VI&II improvers. Since there are none of these in synthetic oils, we will instead concentrate on shear pressure as a result of flow and cooling.What about oil shear?
As I said above, synthetic oil contains no viscosity improvers.
the engine wa s originally designed by an asian engineer, later upgraded by the BMW engineers w a F-1 style valve train.
I think 0W40 can be dangerous for drive train, especially in Spain.
I'm using the Petronas every day in cars and is more cheap than the Shell because I buy a lot of it.
40W..same 90w wth ok lets just go ahead and open this cana worms who's are in house petro engineer surly there's one outa 1500040W motor oil has the same viscosity as 90W gear oil. How can that be dangerous for the drive train?
