My valve cover gasket had RTV on the round areas from the factory. I have since cleaned it off and don't use anything on it. So far, no leaks.besides getting seepage from the bottom of the water pump, i am also getting some from the valve cover around the round areas. i already took the cover off and cleaned the gasket but its still seeping. is that a common thing also? should i rtv silicone that too?
It has a o ring and a seal
what year and modelany idea of the part number for the seal? i didn't see it on the parts list
2008 te510what year and model
Here is my installation thread. It was pretty straightforward.
http://www.cafehusky.com/threads/installation-of-oversize-water-pump-2009-txc-450.25153/
Just noticed tonight (leaving tomorrow for 4 days of riding) that I have small seep of water from weep hole. Thinking I should be all right and address it when I get back. Keep your fingers crossed for me!
thanks. nice write up.
as for the seal being replaced, is that right behind the impeller and if so, is it an easy out or is there a trick to it?
