I always thought this bike was kinda Ez to change the oil on.I like the side drain. Make a quick tinfoil dam for the oil to not flow on the frame and drain it. Flop the bike on its side and do the filter. I hardly even look at the screens any more as there is never anything on them.
- Do not drill the end cap, thats a good way to introduce shavings into the motor.
Max fill is actually 1150cc, many of us feel this is minimum fill. With the addition of my oil recirculation system, you can run a bit more which really cools and quiets the engine.I filled with one quart. On the kickstand, the oil is right at the level of the filler hole. That's all she holds. One quart is enough oil to circulate and keep things cool. Things should get "hot" but what is "hot" as that's a subjective term unless you measure the temperature and compare it whatever "too hot" would be.
If all you can put back in is 1 quart, I'd be willing to bet you aren't getting all the old oil out.I filled with one quart. On the kickstand, the oil is right at the level of the filler hole. That's all she holds.
charge the galleries for 3
I'm a little slow. Can you explain?
************************************************************************************************************************************************************************************************************************************Did the first oil change on the 511.
Little background I had a 06 450smr husky before and a few other high maintenance bikes. I had no problems with weekly/bi weekly oil changes on those bikes.
First how the f do you guys get the oil filter out of the hole? I tried everything! Eventually I punctured it with a sharpened bicycle spoke abd hooked it out. At one point the bike was laid on its side with me trying pliers, screw drivers, the works!
SO about 45 minutes later. I then try to pull the screens. One comes out with a spoke/hook end easy. The other has nothing to grab really. I dont recall how I eventually got it out.
Okay got everything back together put my new stainless oil filter in and go to tighten the screw cap, it goes on easy then realllyyy tight. So I pull it out and the aluminum threads are kind of messed up toward the end. What a fragile piece of junk! I filed the threads and used a bit of grease and just torqued through the "tight" spot. All has been good so far.
I must have set the cap down hard on the threads or something, but looking at them they have hardly enough material to bite. If you had a piece of sand in the case threads it would obliterate the aluminum cap!
Also another slight annoyance is how the oil drains right into the frame. Oil filter removal puts oil everywhere.
Anyways, not looking forward to a thousand more of these. Any tips on filter removal?
I think since its getting road miles I could drain and refill clean all the filters every other change. There was nothing on the screens and nothing noticeable in the filter when I sliced it. The drain plug magnet had a ton of sludge or fuzz. No large chunks (yay got a weds bike).
Now if the chain did not get sloppy loose every ride I would be happy. I have to tighten it every ride or two (45 miles round trip).
