TE449 Dyno results
My te511 dyno# 52.18hp with custom air box mod, pcv, fmf4.1 and she is beastly. However not hard to ride compared to my 01yz426 with jd jets and stage 1 hotcams. That freaking bike is a handful. Overall Power delivery from the fi on the husky is boss!
That's perfect and plenty fast, while keeping the power linear. The next ten HP cost me several thousand dollars and has a much steeper power curve. The oil recovery system is highly recommended at these power levels.
Can you tell me which pcv map you used, fuel, oil and sprocket ratios?
Ordered my airbox cover..thanks guys!
Since we are on the subject of making power has anyone tried to lower the operating temp in the hopes of making a bit more power? Generally vehicles with a emissions are set to run at a higher temperature so getting the temps down may be of some use.....just curious.
Tinken,
I've had my deposit in since late august for the oil breather mod. So yes I agree with you on that one. In the meantime I'm doing 8hr oil changes and frequent air filter cleanings. I originally loaded the zipty race map on the pcv then I had lee's cycle dyno tune it from there. I'm running 91 pump gas, mobile 1 0w40 oil, stock gearing set up for off road, 46 tooth rear sprocket on my super moto (which I dyno'd it with).
