Are you saying the cold start/idle adjust knob changes the TPS voltage? Turing the idle adjustment alters the TPS?
, but this EFI thing is a humbling experience to say the least.
Jam,
Excellent info and great video. So on your previous post you were saying .74 volts on the TPS combined with 40 turns out on the idle produced good results for you, correct? Please verify that this setting applied to your 2014 TE310. My bike idles perfectly at 34 turns out, should I expect that to change as the TPS voltage is increased? We'll be increasing fuel in the mixture but will that necessarily impact idle speed? My buddy just got a steal of a deal on a new 2014 TE310. It was surging at idle. When I checked the idle position I found the dealer had set it to 47 turns out. I adjusted it to 34 and the now the bike purrs at idle. We have a harness coming so we can test our TPS settings. I know mine has been changed as the paint marks do not line up. The video shows the connector on the KTM at the throttle body under the rubber housing. Does the TE310 have a connector in the same position or is the connector under the tank at by the ecu?
Nothing like seeing what others are doing to their bikes to make you fuel the economy.
I know you were asking JAM, but I think I can answer the question for you. On his 14 TE310R the setting he was running was .74vdc on the TPS and 40 clicks on the idle adjustment. On my 14 TXC310R, I am at .71vdc on the TPS and 37 clicks on the idle adjustment. The idle adjust seemed to act like a mixture screw. As we increased to fuel flow we also had to open the idle adjustment up to allow more air flow. The connector is kind of tucked up under the side of the tank. You can get to it without removing tank. Its a little tight, but doable. We made the adjustment to mine in the parking lot at the trailhead in just a few minutes. I am kind of interested to see what others find as the factory settings, and where they end up adjusting it to. And how the different base maps effect the setting.
Did you have the LeoVince map loaded? Even with this map, the bikes run on the lean side.I guess the power issue is relative, I am a fairly big guy, 6'5" 225-230lbs.
