clutch dragging and adjustment help
it was fine all day then started to slip at take off / the start but it was pretty much unusable tried backing off the rod well checking it . i think its nearly worn out ans the soapy diesel oil isnt was the final straw . interesting it lasted like 5 races before that . i guess that was only really 10 aplications of the clutch tho .so it could have taken that long for the oil to soak into the friction disks
i have been using rotella diesel oil but its also jaso rated and is known to be great with clutches and shifting. my local napa has been out of amsoil. not sure about the stuff you tried..in my experience when there is an oil slipping problem it happens pretty much as soon as you put it in. im not thinking it would been fine all day then started slipping just from oil.
I adjusted the set screw and hex loc nut on the clutch push rod that goes through the tranny/clutch shaft till it's about 1/16" to 3/32" of free play. At the clutch lever on the block if the cam isn't worn its between 1/4" to 5/16" movement on the lever.
Don't make the setting on the set screw at zero play because this shaft does grow a tad longer as it gets hot.
This is a good upgrade for all of the primary kick engine bikes for all years. I have made the pushrod at 8.6mm diameter too, so they dont flop sideways when the cam moves it - but still loose enough to operate and get oiled. Re - assemble the clutch and adjust the arm to give 8mm of play. Fit the cable and with luck the adjuster at the bars will be mid-range. Oh, yes - be absolutely sure to use a Magura clutch lever. The mechanical advantage of the modern levers is not the same as a magura!
Hope this helps!
Andy Elliott
Will this upgrade work on a 79 250 OR? New style shaft and bearing? I have my engine apart now and noticed the declutching shaft has the worn dimple. I would love to smooth out the clutch feel.
Thanks
Marc
