1928 Husqvarna Model 200
Okay, I give up. What are the black doohickeys and the chrome-ring thingy.
That piston looks trick. Did you get two of them? :D
The two black things are the high tension pickups out to the spark plugs The round doohickey is the cam advance You have to manually advance and retard the engine and that's how you do it You rotate that left or right 33°
You got the new Pistons but I'm a little puzzled by why the pin is so short The wrist pen only goes into the piston on either side a little over an eighth of an inch I don't understand what that's about I'll have to talk to The Piston guys Monday
It is great to see that our swedish oldtimers get running again @DeathFromAbove, also abroad! It would be cool to meet one at the roads when visiting the U.S. :) Nice that you found new pistons! It is originally aluminum pistons in the 200 model (but not in the 180 which had cast iron pistons).
Thanks Bjorn,
I am very happy you found ME!!!
The Parts Book shows the proper pieces and not the drilled and tapped (locking pins) to keep thing from spinning. I think those pieces should be a tight interference fit .
Thank You SO MUCH!!!
I am working on the translastion of the latest pages.!!
I will send pics of the Horn that came on This Bike!
And After a 2 month Journey the Magneto has new parts and is working well also the Dyno is putting out 8vdc per my Mag guy Leroy!!
Moving Forward Again!! :)
A Special Thanks to
Holger In Germany
Theodoor In the Netherlands
Marvin in Cow Country PA
And Leroy over in Lititz PA
Thanks for all Your work Fellas!!
Great Day in Husqvarna Land!!
Bjorn has sent me a Trio of Manuals for this and a few other models.
I will post when the Translation is complete!!
THANK YOU BJORN!!!:love:
Projects Live and Die by Manuals and Information Shared!!
Thanks to You, Friend!!:cheers:
Chris
Got my original cases back from the 3D printer.
He's got a lot of small stuff to do on the 3D side but he got all the numbers he needed up to that point. I think this week those cases are going to get the welders that they need along with my turbo stuff that's going to get welded up too. Then the turbo stuff goes off to Chrome and I can start rebuilding the Husqvarna engine. Just waiting on valves. Waiting patiently
Finished some repairs on the original cases
Baked them at 600deg for 4hr and still oil is making welding near impossible.
The pushrods/cam followers have an adjuster and lock nut on them but are short so the adjusters are on the last thread. NG
Finally found the thread size for those Freakin' 5/16-24"!! I'll ASSUME they have been changed but look pretty factory to me. Moving on.
I can now make new adjusters and with the 5mm extra on the valve stems give me a total 1cm over the old setup. Meaning the adjusters will be just past center on the Pushrod/cam follower threads. My new valves should be here this week and then the retainer Hole/Slot will be machined. Then I can re-assemble the engine with the new Pistons. This Engine Will be Re-Built like It Should have Been on Delivery!
I rolled it 50 times with the cover off and adjusted the wheels. I think the left and right wheel connected to the crankshaft are okay if there was the original position but the intake cams are off by what I would say about one and a half two tooths.
I put it there after watching compression stroke and then the roll over between exhaust and intake on the second half stroke. I think I'm as close as I'm ever going to get.
We're about to see to put the Pistons on too tall. A new Pistons are nfg. I'm going to have to cut them.
But I think a better idea is to take an old piston overnighted out too j&e and have him measure it up and then him ship it back to me ASAP. Or maybe I'll just wait till next year and run on the old beater. Pistons just once through the park I suppose. And every now and then up and down the street till I get it right.
There's still a ton of stuff that has to be done. Cables, brakes, electrical? It's all been fubarged looks good from a distance but dang.
Engine in the frame.
We'll see if we can get her to fire on Independence Day.
