Johnrg
Dynojet installed all parts as well as dynotuned my bike this week while I was on a mtb trip to Cedar City and Gooseberry Mesa. I wanted a switch and the ability to utilize a second map for high elevations and future tuning if I was to go for a pipe at some point or after engine work. Owners are limited to Map3 which as you can see by the table from my PCV is very good in any case. Only minor map changes were made on the dyno. Looking at the dyno files the bike has 29.6 HP and I think 18ft.lbs torque.
It's nice to have a wide band O2 sensor now and a map switch to be able to switch autotune on and off and switch between two maps when autotune is shut off. Cost to me was free for the PCV and all installations since they thought maybe this would be a marketed kit. They did say when I picked up the bike that I am the exclusive PCV owner on this model year bike as they may not in the end make a kit due to being a short end of life model. In the end I paid cost for the Autotune module and switch.
Screen shot of the base map and dyno trims...
Modules installed neatly on the right side...
18mm O2 Sensor in place of stock 12mm (required removal of stock 12mm mount and and welding on the mount for the 18)...
Routed under left sidepanel ...
Switch...
3 days of high elevation riding in Utah during install...
While most would never need or want this, I may own this bike a long time and nice to have the options to tune. Contact Chris Kelly at Dynojet if you seek a PCV for the '13/'14.
Switch...
