So that rock hard TE310 seat had to go. So I ordered a Guts racing soft seat foam.
The white foam is the new seat.I could not tell any difference in the cut of the foam.
You will have to remove the seat attachment hardware which was easy to get off with a large straight edge screwdriver. Just pop off the plastic washer on the bottom side of the seat.
What I did here was to remove all the staples except the front lip. Before removing the staples though, I took a red sharpie marker and traced around the seat cover. This gave me a guide where to re-staple the cover to without making the cover too tight or loose. In the end it helped a lot.
In the above picture you can see the sticky glue that was on the seat. I left it because it would hold the seat cover pretty good while I stapled the cover back on.
I ended up using a hand stapler that worked well with 3/8" staples. Every so often I would end up with a staple that didn't sit right. After adding other staples I went back and replaced those so they all ended up flush.
The finished seat back on the bike, you can't even tell. With the stock foam I could just touch my toes to the ground while sitting on the bike. With the new foam, I can now touch the ground flat footed. Thankfully, I could not feel the seat pan at all, which was a concern at first. So time will tell if that changes though. Hopefully the foam won't break down.
Cheers
Doug
Cheers
Doug
