630 Rekluse
Discussion in '610/630' started by hammer, Feb 10, 2012.
  1. hammer Husqvarna
    Just tried my Rekluse from my 08TXC 450 Part# RMS-856 in one of my 630s works perfect.
    Just use the standard 450-510 setup.
    drrags and Flying Trash Can like this.
  2. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Which Rekluse is it? Zstart?
    I am happy to hear that, but why didn't anybody figure this out before?
  3. gregjune Husqvarna
    San Diego, CA
    Good to know, never rode a bike with one but I feel the 630 needs it.
  4. SilverBullet Husqvarna
    Harmaston, TX
    2011 TE630
    Hmm, my thinking also. Especially since the 630 has the same clutch as the '06-'09 610
    _
  5. organ donor Husqvarna
    Berlin
    Got a slipper on my 630. Very noticeable when fast cornering, flipping through the gears. Wouldn´t like to be without it.
  6. rho0815 Husqvarna
    @hammer: I can't see the advantage of a Rekluse over a slipper in a SM, please explain...
    @organ donor: which slipper do you use?
  7. hammer Husqvarna
    Never said I installed it in an SM.
  8. gregjune Husqvarna
    San Diego, CA
    Whats the difference between rekluse and a slipper? Advantages?
  9. organ donor Husqvarna
    Berlin
    Italian STM
  10. Bunny007 Husqvarna
    Niceville, Florida
    2011 TXC449
    Hammer, which Rekluse did you install?
  11. Bunny007 Husqvarna
    Niceville, Florida
    2011 TXC449
    Never mind, Z start pro RMS-856 found on Rekluse's website. Can you explain how you did the installation?
  12. hammer Husqvarna
    Did you ever get one installed? How do you like it?
    Just to let everyone know this clutch works better in my TE630 than the TXC450 it came out of. I wish I had it in the 630 when I did 8 days in Baja.
    gehtlos likes this.
  13. Bunny007 Husqvarna
    Niceville, Florida
    2011 TXC449
    Not yet due to other projects. It is still on my list. Your input is much appreciated as I would never have known Rekluse makes a clutch that fits the TE610. FYI, my dad is a University of Toronto graduate!
  14. hammer Husqvarna
    He must be a smart man then.
  15. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I got one in my 610 and like A&H says, it works better there than in my WR 250 and TE450. The manual override is better than the stock maual clutch, with very little effort. Very nice.
    Thanks for the heads up!
  16. Bunny007 Husqvarna
    Niceville, Florida
    2011 TXC449
    Xcuvator, dId you also use the RMS -856?
  17. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Yes I did. If you order one get some extra TC balls, I used the six that the kit comes with plus three more I had from another install.
  18. mike54 Husqvarna
    why the extra tc balls xcuvator? can anyone who has put in the 856 talk about the install?
  19. mike54 Husqvarna
    can anyone please comment on this? the guy is not talking about a 630 by the way
    "As far as the install goes, the instructions are pretty good, but the section relating to putting a spring on the Clutch Throw Out Assembly was ambiguous at best. It covers the '06-'07 450/510 models but not other models. There is one comment under the '06-'07 450/510 models section that says all other models do not require a thick spacer. The next step then related only to '08 450/510 models - to put the return spring carrier on top of the thrust washer - there are no instructions for other models regarding the "return spring carrier" yet in the next step it says to place the C150 spring over the Spring Carrier. So installed the spring carrier without a washer and hoped that would do the trick."
  20. huzar Husqvarna
    Seattle
    Anyone know if the Core EXP for the 510 would work in the 610? Comes with the ability to enable bump starting, and a new clutch cover that gives a little more oil volume...
