GaryM
Change oil as often as possible. Learned at very great session at Barber vintage - moisture can be in and around oil but not mixed in in it. The worst is someone who
never starts and runs bike and make it hot. A hot running bike burns off the internal moisture. As daily temp go up and down at night condensation from inside the crank case the condensate forms on the exposed metal of case, may even top of gears , top of exposed clutch etc. If you never drain like old bike tranny. or old fork oil - it looks like in has water in it or watery fluid. Gray in nature or just plain does not look like the oil you put in it.
Well that some bad oil there. Had to think about this for a while. They found in recovering old bikes, that the internal gears and metal parts even inside
a stored bike with oil in it can have damage. So now I am changing it in the running bikes - and changing in my bikes that don't get run much at all
