What a difference a tooth makes!
TE 250 Girl
We changed my front sprocket from a 13 tooth to a 12 tooth and WOW!
Its like a whole new bike!:thumbsup: I wish he had done this from the begining.
Is adding more teeth to the rear too much? Or does it just get better!!?
you could try going up 2 or 3 tooths on the rear and use your 13 it will save a lot of chain wear as a 12 will wear out your chain/guides faster just try good luck
+1....a 13 tooth is as low as I go on the front, going lower than that put's the chain into a tighter bind/bend. Just my .02
1 lower in front = 2 1/2 higher in the rear...
I think that's right. Going more on the rear is better for your chain but a little more money for the sprocket.
:cheers:
Does anybody have any proof that a 12 tooth sprocket causes extra wear? I've ran them for years without any problems...
I have only personal experience when I went one tooth down in the front, I believe the cog and chain went at about 800 Kms (teeth hooked and chain hadtoo much latteral stretch). Going back to stock at the front and up 2 teeth at the back was better, fractionally less lowering but better top speed (or lower revs). I do admit however that after about 1500 kms I tried the stock gearing and preffered it. I put that down to the bike freeing up and me getting better at reading the bike and adjusting/changing gears correctly.
12 tooth guy for years never had any abnormal wear. At the same ratio a smaller front will give better
acceleration and a larger rear will roll freer and carry speed better.
I once bought a 12T and was laughed out by 4 techs for doing it. Aparently its a no no as far as gearing math. :excuseme:
Maybe i should start giving back the trophies? :D
12th witouth problems. (and this.on a te510, which.is known as a chain eater). have 1900 km on bike and chain is still ok. i prefer to change the front sprocket because it allows you to go back in only a couple minutes if you have a faster trip.
Other than Moab once a year, I just ride ride single track/trails. With a connecter fire road here and there. At Mount St. Helens we have to ride pavement for some time to make a loop, but Im OK with the slower top speeds if its easier to ride the technical stuff (ie switchbacks).:thumbsup:
It does suffer a bit at higher speeds now.
A larger problem, is my chain "sliders(?)" are wearing out because my bike is lowered so far (4"). I wont let my boyfriend raise it up though.
He is going to look into an aftermarket type? It is supposed to wear better. Last a little longer I guess?:excuseme:
There are aftermarket chain guides T.M. and BRP, but I have not seen aftermarket swingarm chain sliders (and looked). I am on my 2nd OEM one and am going to order another as a spare. (09TE450) I think the stock chain has sharp edges:excuseme: (never really had to replaced these on other bikes) again :excuseme:
