what 2 do with o2 senser 12 txc 511 fmf header?
huskyrob450
Going to install powerbomb fmf exhaust,older threads say install map#2 and just unplug o2 senser. Is that a reflash? The 2012 ecu is locked out and cant be reflashed according to zipty. Or is the #2 map something that plugs in ? The resister plug that j d sells doesn't fit , he's fairly certain the tuner will not function unless I plug it. Thanks for any help
PS, you shouldn't plug anything in where the O2 sensor plugs in. There is no resistor, just a shunt/jumper that plugs in under the seat adjacent to the ECU. There should be a loose connection with a cap on it.
allright !!! I found the jumper with owners manual, installed it and fixed the low rpm surging and no flame out yet. Thanks Texas!!!
Welcome to stage 1 tuning for the Kymco engine. Think we should initiate a campaign for ZipTy to resolve the unflashable ECUs, I'd love to have map 3.
The tool needed to flash the TXC's is $6k dollars. We raced the TXC511, Nick Burson's, and it used the pcv. Flashing map set #3 into your stock ecu no where compares to the addition of the powercommander.
Thanks Tinken, good to know. Am thinking I should have bought PCV instead of JD now.
Does the PCV work well alone or do you need autotune module etc?
