I have had my share of issues with the bike, believe me. I still love it every time I throw my leg over it. It's dirty, scuffed up, has slid down the street at 45 mph, and just keeps asking for more.What a great dealer I have here in Norwich, he said his tech rode it found nothing wrong with it, when I asked what speed he went up to he replied "60" I said the problem was at 70 as I had told them!!! his reply was well dont ride it at those speeds then................I was gobsmacked to say the least, I have forced the issue with them, saying I have paid nearly £6000 for a bike I can only ride up to 70mph and I want it tested to the speeds it is suppoed to do. This bike has been a nightmare new engine after 72 miles, new speedo after 300 miles, now this at 1000 miles. It may be up for sale soon as I am fed up with it..............
The ideal race sag (ride height) is 103 mm.
FWIW, most shock manufacturers recommend a sag of 30-33% of total unloaded suspension travel, which for the 630's rear suspension is 96-105mm.
Of course, 103mm is in that range, but I'm curious how you arrived at that number. Is it what Husky recommends in the manual?
Loosen the pinch bolts on the forks/axel (4 of them) and bounce the front end as much as you can. You can even have someone sit on the bars while you snug the bolts back up.
My SM seems to be the same even with road tyres.
I think I need to get the wheels off an make sure they are balanced correctly as I haven't done much mileage on it since buying the bike.
When you guys are talking about setting the sag on the rear, this is adjusted by moving the spring and lock nuts isnt it rather than the dial on the side ?
i'm 5 9 and weigh about 170 Pounds
Is it possible to dial the bike in for such a rider ?
Not sure on the SM, but CJ is right about how the TE is set up. The springs are way too stiff. The stock rear spring is 6.4 kg, and after LTR reworked my suspension I wound up with a 5.8 kg. If you go to the Race Teck site you can get their recommendations, which is for a 5.4 on my TE. The 5.8 gets my rider sag just 2mm high when loaded with adventure gear. I weigh a 190 w/o gear on. Husky puts big springs on the TE. No wobbles any more after the suspension work and tire changes.My SM seems to be the same even with road tyres.
A tab washer in the gear box which wasn't secured properly and the nut unwound and caused engine to sieze solid luckily I was only do 30mph at the time only a few minutes before i was doing 60ish!!!What caused the need for a new motor after 72 miles??
Every bike should have the suspension adjusted based on your weight and intended ride environment. To think the bike would come off the shelf all set for you is foolish thinking.
