TXC 511 question
drdfblackm
In my ever quest to make my TXC 511 as much as a dual sport as possible, I found the need of needing a keyed ignition or hidden ignition cut off. Any ideas as to what and how I could accomplish this. I have a set of SM wheels now and well I would like to be able to zip around town on it a bit. I understand it will not make it much more secure but it will give me a little piece of mind.
the SMR 511 has a keyed ignition. Does anyone know if it would be possible to just buy an ignition from husky and plug it directly in to a TE511 or TXC511? drdfblackm, does your dash on your TXC have the little circular spot on the top right where the ignition goes? My TE does, so adding the stock lock cylinder would be e breeze, but I have no idea where or if it would plug in. I understand why they did not put a keyed ignition on the TXC, but with the TE being street legal from the factory, they definitely should have put that option on it.
why not just add a deadman switch?
all you need to do is find the hot wire to the starter button a intercept it with a switch that you can locate in a hidden spot.
i have one on my txc449
http://www.cafehusky.com/threads/key-switch-for-2012-449-511.26785/
2012te511ignition-jpg.18959
Thanks Tinken. I have replied on the other thread. Any help would be greatly appreciated.
