TomGlander
Riding to work today, stopped at light, noticed smoke. Then saw oil. All over the engine. Have ZipTy oil breather system. Been just fine. Never an oil drop anywhere. Until today.
Well, last night I took the oil breather off the head, then put it back on. Have to remove it to get to the sparkplug. I didn't check the hose, and left a nice kink in it.
So today, the oil is everywhere. Is that kink in the hose going to make oil go all over the place? I turned around, and headed for home. Then the bike went into a low RPM mode, like a loss of power. Then it just stopped. Dead. I pulled in the clutch and coasted downhill to a gas station. Lucky me.
My wife got the bike home via AAA. After work, I checked it out. No sign of any issues. I readjusted the kinked hose, and filled the case with oil.
Tried to start the engine. It didn't want to turn over. I tried again, this time a little click. Then again, and it slowly started turning a little. Then again, and it started turning faster. Finally, after the fifth attempt, and lots of turning, faster and faster, it started.
I wonder what was going on internally on the first through fourth attempts?
I was worried it might be seized. But no, it now runs "just fine."
Was that kink in the hose enough to cause the oil spillage into the airbox? I opened it up, and oil literally poured out of there. Cleaned everything up.
The system Tinken sells has worked perfectly. That kink in the hose that connects the breather elbow to the oil bottle was the only change.
So I'd like to know what was happening. RPMs on the way to work are around 8000, running 75 mph. Gearing is 15 front, 44 rear, supermoto wheels. About 3/4 throttle for 2 miles. Nothing different than any other day, except for that kinked hose.
Anyone have any input or ideas on this, love to hear them. I'm glad the ECU shut down the engine. If this were a carbureted bike, and I didn't stop, the engine WOULD have seized.
I think I came real close to literally blowing something up. Thank you Husky engineers for creating a system that shuts things down when they get too hot or not enough lube or whatever you did to save my bacon today.
I should have stopped sooner, but when you're hauling ass on the freeway watching for cars, you aren't looking at your engine and don't notice the oil leaking.
I got lucky today. It's far better to be "good" than "lucky." But I'll take luck today.
I'm going to monitor this thread to see what kind of replies I get. Anyone want additional info, I'll be watching so I can answer questions or add more detail if needed.
