Those Little Things
Headlight indicator lamp is WAY too bright at night. I took a sharpie to it to tone it down a bit. High beam, sure light up and remind me I'm running around with the high beam. But low? Stupid.
I hate everything about the left side cluster switches. The hi/lo switch is way too high to comfortably flick with your thumb. But I love the flast to pass trigger, never had a bike with one of them before. In NY it would be ideal if it could also be rigged up to an automatic weapon.
I never use the flash to pass so I hotwired it to the horn button. I use that one most for self defense on the street. That and a way louder horn. Cam.
It was an easy rewire. The handlebar switch mechanism is well thought out and one of the best I have worked with. There is room in the switch to run 2 #18 wires and solder them to the existing solder pads on both switches. I cut the highbeam wires and sealed the ends. Cam.
Flash to pass trigger is excellent, everyone should train themselves to use it more. My Honda Phantom had one and I learned quickly the benefits. Riding through an intersection or when a car is waiting to enter the road you're on I'm modulating that trigger like a semi automatic. Gets you noticed more even in daylight. Also when riding with others and I need to get their attention I flash repeatedly into their rear view mirror. They can't hear the horn but usually notice the flashing after a while.
_
