TE630 HID conversion
I managed to find a cheap solution to my problem. I was looking for a similar size rubber boot from our local "Bunning" hardware store, and found this item (cost $2) in the plumbing section. I think they use it in the toilet area:
I then fold it over:
and tried it on the headlight assembly, and got a perfect fit:
I need to butcher it a bit in order to fit the HID bulb assembly, and the apply silicon to make it waterproof:
I managed to push back the wiring loom behind the headlight assembly, and the whole thing fit! Not the best looking mod, but it is cheap and functional and you can't see the mess once installed. I now have to wait for the silicon to dry, and put some tapes around it to firm things up. I am looking forward to some bright light!
This is real overkill IMHO and creates more bulk behind the reflector.
If I recall correctly I merely cut the OEM rubber boot to the circular indent around the spade connectors - the HID rear fitting pushed through and butted up nice and tight (extra dab of silicone on edge if you want) and is water proof anyway. A snip of a cable tie or two and realignemnt of the harness and you are done. I had no issues and is working great after 1000km of all terrain use. Will see if I can get a pic of the setup later.
Thanks BIG DoM, Cutting the OEM rubber boot is a much better idea. Here is the picture:
Got it fitted on to the bike. It puts out fantastic light, but is running quite hot. I am now a bit concern about melting the lens. I would recommend anyone considering the HID light conversion to go for the 35W version instead of the 55W.
just cut the rubber where the the terminals protude to a neat circle & fit it that way,i'll look at mine tomorrow & see if it will still seal,otherwise go to a local automotive wrecker & get a rubber seal that dosent have the terminal holes in it,we have fitted many kits in cars that way,& yes i know its not a car,that rear section that will hang out is normally fairly robust
A 55W HID should run significantly cooler than the OEM bulb that it replaces. It might be worth measuring stabilised reflector temperatures with the original halogen and the HID if it is a concern.
In theory, HID should run cooler, but the H4-3 bulb has a large metal shield covering the front and bottom of the bulb, so all the light (and heat) is concentrated in a small area directly behind and above, whereas the OEM bulb spreads over the entire reflector.
I had done a 55W HID conversion on my F800GS a year ago. Both reflectors has bits of silver coming off - but then it may be cause by the combination of drowning and high temperature.
I will stay with the 55W HID in the mean time, as it is a huge improvement over stock light.
Only weird thing about these reflectors is the angled pattern = typical fail of 'form follows function' with a design compromise!
Unfortunately not.
Trying to decide if it's worth going with the 35w HID.
I swapped in a brighter/whiter H4 bulb a while back, without pulling the headlight, so my harness is already zip-tied out of the way :p
Silverstar Ultra isn't all it's cracked up to be, btw...
The difference really is BIG
HUSKY 630 with 55w 6000k HID - CBR with 35w 8000k HID (both on high beam)2012-06-02_16-03-40_565.jpgHUSKY 630 from a different angle (not so blinding)2012-06-02_16-05-32_683 (2).jpgThis is the only before HID pic i could find, had to cut the picture out of a video of my brother taking it for a spin that i took with my phone so quality sucks 2012-05-11_15-02-35_469_01.jpg
