TE511 switching spedometer to MPH
Mikepod
I have a 2013 TE511 and can't switch from KM/H to MP/H. Tried to use manual, but they reference the key switch that does not exist as part of the procedure. Anyone been able to do this?
Put it in odometer mode first and then shut it off, let it cycle down. Hold the button down and restart the motorcycle. You should now be able to change it.
I did it today, it would have been easy if I had a third arm.
Set computer to odometer, power everything down. Get a friend to push the button on the computer so you can make the change. When you pull the clutch lever and to start the bike, the computer will allow you to change from KPH/MPH. When the screen shows a change option, simply press the computer button to switch from MPH/KPH. I agree it would have been easier with a key vs actually starting the bike. Anybody know about an aftermarket key that will fit into the instrument cluster (mine has what looks like a key housing) I think a key would be a great simple security measure.
Just bumping this up today, took me a bit to figure it out as the manual is retardid.
Zip tie the clutch,
Hit the starter,
Hold the button on the odometer,
Let it dim while holding the button still,
After it dims out-hit the start button again, kmh will appear only so press the button to display mph.
This is for the 2014 with no ignition.
