FabOneUp
I know this is a difficult question and there are may variables involved and I will try and include all of mine. I have a trail ride this weekend that requires a few things out of a bike. A fuel range of 75 miles, a cruising speed of 55 mph, and a plate for street use. I had a 42 tooth sprocket which put the cruising speed around 60 and still works well on the trail system involved since it is pretty open with only a few tight sections that I can clutch around.
Mods to the bike are the power plug and FMF pipe only. I believe it will be a casual ride so the throttle hand will be used lightly. I am sorta sure I can make the 75 mile range, but not positive. I have only had the bike for a little over a month and have not pushed it to see, but with the 42 tooth sprocket and casual throttle use, I think I should be fine. Any thoughts would be appreciated. Bringing extra fuel would be difficult , but I will if you guys think I should.
