TE449 Decat
ken_hale
I have a 2013 TE449. What is the procedure to decat the stock muffler? I would consider a FMF slip on muffler, but prefer to keep it quite enough for the woods and nearby homes.
Thanks.
Drill out the rivets on the part closest to the pipe and then it comes apart. Then with a cut off wheel or sawzall cut the cat off. Rivet it back together.
Its annoying and takes longer than you want but its not that hard.
Actually someone said that using a holesaw in the center was easier than slicing it off (which was my method) with sawzall.
I found using a saws all on the pipe was fairly easy. The trick was to move the inner shield out of the was so you are cutting beside the weld not thru it.
I used a 4" grinder to remove the 4 welds holding the (for lack of a better word) the inner baffle to the cat. Once that was out of the way cutting the cat out was a five minute deal with an 18 TPI metal blade with the sawzall. I then used red gasket maker and reinstalled the pipe side baffle and popped in some new rivets and it was good to go.
