TE410E/TE610E igniton stator issues.
NoMad410
I have a TE410E which recently developed an ignition problem and would not start.
Trying to sort it out I realised how poorly supported Husky ignition electrics are, and decided to document my attempt to solve the problem.
I put the thread in the "Older Single Cams" section, as I thought that was the most appropriate, but looking again, I realise that TE410E has far more in common with the 610s and shares the same ignition with TE610Es and SM610Ss from 2000-2006. So I am adding a link to it in this section, and hoping that someone knowledgeable in Husky electric may have something to add.
At the time of writing this I am considering options like rewinding the excitor coil (which is expired) or finding a solution that does not involve any excitor coil at all.
You can read the whole saga, as it develops, here. (reading from post #8 will allow you to skip my initial bafflement and frustration :) )
If any mods think that the thread is better suited in this section, feel free to move it.
Hi -
I am pleased to say that I have fixed the problem of the burnt out excitor coil on the stator.
Rather than buy a new alternator (expensive, and could well burn out again) I rewound the excitor coil with a much thicker gauge wire, and then used an external transformer to step up the voltage. It seems to work very well, plus I think the new winding will be less prone to burn-out, than the ultra-fine previous one. If the transformer burns out, it can be replaced in a minute, without having to open the alternator cover.
I will monitor this long term, and post accordingly, but it may be useful as a solution to others, as well.
The link above will get you to the thread.
