Allan Briscoe
I have about 1200 km on my TE310R and recently went to go for a ride and the bike stalled on cold start up which is often does but after cranking a couple of time on the restart the starter just then all of a sudden just started to spin with out turning the engine over. I tryed to kick start the bike but no go either so I had to pack up and go home. I took the bikeback to the dealer as it is still under warranty and they found the flywheel nut loose and the drive key broken so that explains the no starting on the kick start as the timing refernce is lost. Has anyone else had this happen the dealer and I had concens but Husky Australia asured me that replacing the key and retension the flywheel nut will not happen again. Anyone had repaet failure?
