TE310 Tank insert repair/stripped
Thank You Lankydoug... I'll get a hold of the tool next week and give it a try!!! You posted a link for 6m... Are your sub frame inserts 6m's. Mine are 5m's...... THANKS AGAIN
I don't remember if they were 6mm or 5mm I was just posting an example of the inserts. The tool comes with different arbors for several sizes. These are handy when doing any fabricating when you need to have a threaded hole in a thin metal sheet. For example these are used to mount extended mirrors to doors and spare tire racks and ladders to van doors and trailers.
Just used the insert tool and all is well...... So far so good and it's not spinning yet!!! Is it possible to over tighten on these inserts..... :confused:
To remove tank bolts , heat an 8mm 6 point deep socket to 200/250 degrees , put it on a long extension and rachet . Put the HOT socket on the bolt for 30 seconds then try a quick hit to the rachet in the off direction with a small hammer . Increase time on the bolt as necessary . (this process makes the bolt shoulder grow away from the insert face) .
Treat it just like a rivet when it stops compressing your done. You will quickly see that the factory didn't even come close to getting them tight.
This thread can get a little confusing because we are talking about tank inserts and sub frame inserts which are completely different. For the record, I'm speaking only about sub frame inserts.
