my_urban_chaos
Has anyone ever upgraded the TE250 to a TE310? What would need to change? Just the top end and piston? What about the ECU?
Don't forget exhaust too, the 310 cyl/head is taller.On my 2010 txc250 i had to change the crank, piston, cylinder, head bolts, cam chain, cam chain guides, oil line and bore the cases to make it a 310.
I didn't have to change exhaust.Don't forget exhaust too, the 310 cyl/head is taller.
I needed to replace most of the parts anyway so to make it a 310 wasn't much more.ote="joedirt, post: 308466, member: 2069"]On my 2010 txc250 i had to change the crank, piston, cylinder, head bolts, cam chain, cam chain guides, oil line and bore the cases to make it a 310.[/quote
Sounds expensive has the change worked out for you.
Does a longer stroke crank cost more to make?Yep, the xlite 310 has a longer stroke than the 250 hence the extra expence (and work).
Probably a few cents. More cc's, pay more $$$!Does a longer stroke crank cost more to make?
The 310 doesn't have more parts than a 250 just different parts.
