TE 511 > 2011 suspension settings?
Any idea what size hook wrench I need for the rear shock, or are the hinged ones any good?
It may be primitive, but a big flat screw driver or drift and deadblow hammer works quite well for me. Use the screw driver to break the lock ring loose, then use your hand to twist the spring to tighen or loosen preload as needed. Use the screwdriver and deadblow to retighten the lock ring - not too much...
Sorry to upset everyone with the "ad" comment. I offered respect and was just sayn'. I have conducted positive business with both Motosportz and Zipty and would recommend both. There is also, IMO, somethig to be said for folks helping each other out when DIY is an option as well. Which, I know, Tinken and Motosportz do as well. Just lately...
Thanks. Kind of what I'm doing, btw. But on a previous bike I used a hook wrench and it was so much nicer a process when the spring starts to get tight. For $10 - $12, might as well. Not a lot of room to fit a hand in there, too.
Use a drift/Screwdriver to unlock it (you will never get a hook wrench in there), back off the lock nut and then turn the spring by hand to adjust. Bike should be on a stand so there is no weight on the back end.
That's what we do.
I just reread this. You said to turn the spring by hand. I read it as turning the the top ring by hand. Turning the spring makes sense. I would never have thought of that.
Right, the spring should turn the ring nut as you turn the spring.
I did it the hard way for years until I learned this trick.
