hsq449
Hi everyone just to share a problem that i've encounter over my last ride up in the high country vic.About 25min into our ride the fuel light came on and pulled over to see why knowing that is full of fuel ,anyway traced the problem to a sticky fuel tap(main tank) and a partially squeezed breather hose .For some reason the main problem was the breather hose i've must done it when i removed the plastic side cover.As i was trying to work why no fuel feeding into the clear tank i played with the taps turning them off and on several times ,which are prone to get stuck closed and only if you take it off and push it open with a screw driver or similar is the only fix.So if your fuel light comes on and you know fuel is not an issue check breather is not pinched.
