TE 250/310 screw rubs coolant line
I may have confused you ,its on the underside of the fuel tank most likely the fuel pump cover screws,next to the waterpump hose clamp when on the bike.
Husky you need to correct this at all the dealers / spoke to a raceteam member they have had same problem!
Just to add, if you go the Zip-Ty route, be sure to loctite your tank bolt. I also added small washers and 1 lock washer to allow the bolt to still have a solid surface to tighten onto. If you just tighten it with the HD washers and the original rubber washer, it tends to vibrate loose rather easily.
