Gotta love the Husky community!Kevin2735, Bring it by the shop. It's under warranty, we can take care of it for you.
Paul
Sorry this took so long, but have been busy working and riding. The cause for the blown fuse were wires for the rectifier that were pinched underneath the battery. My 630 had only six hundred miles at the time this happened, so I am guessing that when the bike was assembled they ran the wires incorrectly. This short seems to have blown up the speedo so the dealer has a replacement for me but will take two more weeks to get. When I picked up my bike, the dealer told me everything was fixed but when I got one block away noticed the speedo was still inop. A brief test ride would have shown this, so I was a little frustrated about that. Otherwise, the dealer support has been good, they warrantied everything and put the new sprocket bolts and clutch push rod on for me. If you haven't done so, I would check those wires near or under your battery and make sure they aren't pinched.
I have been having a problem with my battery voltage dropping as I ride and after 20 or so miles my bike will refuse to start. I pulled the battery and found that I had the same issue as you did with the improperly routed harness. My red wire was chewed through and one of the yellow wires needed some TLC as well.
After I fixed that issue and charged my battery, the battery still discharges about .01v every 15 seconds or so.
I'm stumped and starting a new thread.
