Spark plug
avatar4281
The stock plug for my 09 TE 510 is an NGK CR8EB. Can I use a CR8EIB (Iridium) plug in its place?
The reason why I would want to (and this may be a bad reason) is that I am troubleshooting a problem where is seems my engine delivers too much fuel when it is hot and just off idle (all other RPM is great) causing the bike to stall. Part of my troubleshooting is replacing the plug, but I wonder if getting a slightly different plug may solve the problem. Unfortunately there is no information about plug types, etc. that I can find useful.
My bike has a Power Commander IV with Autotune. It had this problem before the PCIV, but the PCIV really smoothed out the fuel delivery and lessened backfire. I also took it to the dealer to have them look at the iBeat whatever it is twice, and they adjusted it, but I still have the stalling problem.
Can you post a pic of what your stock plug looks like? Like the one below, the left side pic is mine, my bike is programmed rich.
I wouldn't think that a different spark plug would cure a rich stall problem.
I have been running the CR8EIB-10 for a few years in my 09TE450 with perfect results. http://www.cafehusky.com/threads/spark-plugs-caps-and-coil-connectins.12265/#post-197804
Your running issue may have more to do with fueling issues however as suspicioned. I don't have any PCV experience- but I'd look at trimming the lower throttle possition area. ALSO ensure that if they (with Ibeat) checked your TPS to see what they set the WOT to... 100.2 % has been consistantly making large difference on every 450/510 I have come into contact with.
Here's the spark plug. I haven't changed it, but before I fixed my PCIV the bike was very lean, now it looks like it is rich.
That doesn't look too rich to me, mine is richer looking than yours and mine never dies. I would wonder about the particles burned into the electrode, although some of the "good" plugs below have alot of deposits on them.
According to the chart I would say it looks pretty darn good. I still got a new one, but don't think the spark is an issue.
