Hi, do you have any picture of the lowered bike?In Australia, the 250r and 310r have exactly the same seat height. The lowered 250 was only in the US.
However... I had my 250r lowered and set it up for my girlfriend. It was lowered 50mm internally. No lowering link was used. It's all reversible.
Thanks, How much was it lowered? Did you ride it when it was lowered? If so, any negative effect beside limited ground clearance.
Boogie, Do you have a Picture of the lowered bike? I would be nice to see how it looks when it is lowered the same as I intend to do.
Have you cut the kick stand?
Very good. Thanks!I had a look for pics but the ones I have don't illustrate the lowered bike well. Its on the stand and photos are on an angle so its had to tell its been lowered at all.
Here is one from the net of a te250 lowered approx 50mm. Mine looks like this from the side.
here is some info on this bike below: http://www.dirtbikemagazine.com/ME2...0&tier=3&nid=A8815CD64C82414CB19143C72FD81E1C
Hope that helps
Yes, but you have to calculate the hypotenuse. You have to cut a bit more than it was lowered.You can put wood under the tires to lift the bike up, and then shorten the kickstand by that much.
