Really good JD settings for 2012 TE 511.. Here !
The Air Screw, seems to be set to high with the engine ticking over to high and when trying to just roll on it is trying to run away, turned it down so its ticking over nicely, surely the 2.25 turns can't be set in stone as the best setting? Or am I missing something?
Your off topic . If you don't try these setting then no need to post. :)
I have an "off topic"? Oh, I wager that you meant "you're", better known as "you are", which is a subject and a verb as opposed to the possessive adjective of "your". I was confused and searching for my "off topic" for a few.
It is on topic. On the topic of how awesome the PCV is and in life, there should be no reason to have to jack with this sort of stuff when an animal such as PCV+AT exists.
Could be the nature of the production line . The machining of the throttlebody and air screw could make a 1/2 turn difference ?
PCV industry owns your performance now. May the force be with you....
