Radiator Guard options for 630
Installed the Motosportz radiator guards. They fit the 630 and make a very stable impression. But installation is not as easy as it looks. Easiest part is unclipping the OE vanes. Then the side tank panels have to come off. It would have been easier to remove the tank (but I didn´t). Fitting the bolts for the guard was a bit like work for an obstetrician, but if I can do it, suppose anyone can.
+1, Good guards, great price.....kinda a pain to install tho.
A tip that makes the install easier is to use a long T wrench to reach the inside bolts and not tighten them until both are in. Without a T wrench you are left to extensions which are wobbly and harder to the the hole. Mike.
The hole for the socket doesn´t quite line up with the bolt head. And there´s no way to hold the right hand lower bolt head while tightening the nut (or am I being exceptionally thick?). But it CAN be done (even by me) and the guards do fit and certainly provide very good protection. Unless someone comes up with a better idea, I´d definitely do the same again.
