Richard Maxted
Good day all
I am new to this forum and hope that I will not infuriate to many "quad bashers" that are members on this site.
I am building a Hybrid quad using a Suzuki LTR450 Frame and a 2009 Husky TE 510 motor. I have managed to pick up the donor bike complete with wiring, TFI and everything I needed for the build. I subsequently also managed to pick up an 08 SMR 510 with similar bits and pieces, all for a very reasonable prices.
The reason I chose this motor is that as much as I appreciated the Suzuki LTR 450 motor, I was always looking for the next gear. As this quad is specifically being build as a desert racer, I had to do some research as far as 6 speed transmissions were concerned. I had previously burnt my fingers with the KTM RFS platform so I was weary to wear that badge again. I found that the TE 510 had almost identical transmission ratio's from 1-5 and the sixth was the cherry on top.
I have a couple of questions that I am hoping you learned Husky guru's can answer. I find it strange that I cannot seem to find any performance enhancing cams etc for this motor, or am I just not looking in the correct places?
I am I also interested in any input as to fitting an external oil cooler, as I believe that I might possibly need a small increase in oil volume, considering my application.
Where on this site will I find the "classified" section.
Anyone have any good PCV programs/maps?
