justintendo
klotz super techniplate junkie
yes the sem was pretty fragile as well. modern new replacement stuff is on a different plane of reliability than sem
I suggested the hard starting could be the carb. The jets or the choke system could be hummed up from sitting. If the balance is off or the idle speed screw on the sleeve in the carb is too far in giving it way too much air. This can be caused by the balance being off and were compisation by turning in the sleeve screw trying to make it idle. It could be the previous owner messed it up. Brothers I been there many times.
Lower the idle, balance it to the best rpm, lower the idle again and lower the idle again.
Clean the carb first. Make sure the air cleaner is cleaned and lightly oiled.
I like seeing them respond to readjusting it till they purr. They start to talk to us.
I will try to make it work with what I have. I have already tried to change out the wiring, bypassed the killswitch. I will se tonight what await when I take the flywheel offI'd check the whole wiring on the ignition system for a bare wire for a short too. If you have a kill switch check that too for s sticky button. For me the points and condenser ignition systems in any piece of equipment once the points are cleaned( a point file) and regapped it should be more reliable than a cdi SEM ignition. Done give up on it these are awesome bikes.
In a pinch I carry a piece of fine grit sand paper in my wallet. I clean the points then fold the sand paper smooth side out and put it through the points to remove and loose grit that can hold the points open. Trust me this method works in a pinch.
As kids we were in New York drinking one night. The 58 Chevy we were in stopped running. No spark. We used a match book cover were you strike the match. It worked to clean the points and we made it home.
MaCGyver has nothing on the guys on this forum where all unmatched were the best. We all bring something different to the forum.
