Russ Henry
Coolant is the first thing we checked. Was fine.Sounds like bad temp sender or low on coolant
Interesting, I had thought about the sensor, but I did not think it would cause the leaning symptoms.Sounds like bad temp sender or low on coolant
Could having the air screw turned out more than 2 1/2 times do it ?Interesting, I had thought about the sensor, but I did not think it would cause the leaning symptoms.
The bike has ran great except for Bend. That was just a coolant issue. I rode Saturday and it ran great all day. Sunday to about 10 miles then it crapped out. I just remembered that I did turn the air screw out another turn on Sunday. Is to much air the reason ?Sounds like these guys are right on. Could be a dirty injector but seems odd it would idle and run wide open but not int he mid. Temp sensor might be it but usually they don't like to start and idle with a bad temp sensor. Do you have a JD tuner on this? Yes? Maybe try bypassing it back to stock to eliminate that from the equation? I have seen VERY little failure rate but when you chasing a ghost you need to eliminate the EZ things first. I take it it has ran fine for several rides since riding it with no coolant at the gathering? And yes, i run some Berryman fuel injection cleaner in mine. also a splash of seafoam once in a while.
It then started flaming out and stalling at the lower speeds. I solved the issue by giving it a bit more throttle but the problem got worse as the day went on. It then started cutting out unless I was reving the pee out of it in any gear or speed. When it stalled. I could hit the button and it would start right up and idle fine but when I gave it throttle to go it would die unless I really reved it hard.
When racing, we change out the fuel pumps at certain time intervals because they do wear or clog over time.
As you increase your throttle, pump psi climbs.
Excellent. That was the first thing I thought of because you seemed to have similar symptoms at Bend last fall.Coolant is the first thing we checked. Was fine.
Yamaha's too.KTMs are having all sorts of pump issue with clogging due to tank manufacturing slag.
That is a good question, looking at the schematics, the 449 show's a pressure regulator, but I have been told that the ecu can vary voltage to the fuel pump to increase/decrease pressure as needed.With a mechanical, 45 lb pressure regulator (45 on mine at least, tested) how can increased revs increase the pump pressure?
1. I turned the idle screw out to increase the idle. 2. In Bend the coolant was low so when we stopped it would not start because it was to hot. It ran good other wise. On Sunday the bike would start but would not run unless I revved it hard. Plenty of coolant on SundayDid you turn the air screw to increase a declining idle speed? What happened with the coolant? Did you overheat? Do you run a higher PSI rad cap?
I dropped it off first thing yesterday. won't get to it until tomorrowSince Bill piped in the other night....I dont doubt that he is waiting for you to bring it in so he can take a crack at it.![]()
