keep bending bolts on handle bars... help!!!
There was a thread on here where the single clamp was twisted, if its an issue and your not fussed about keeping the middle clamp remove it and cut it into the two seperate ones.
every week or 2 i end up wiping out and bending the bolts that hold my bar clamps on... i dont know why, my friends wipe out as much or even more then i do, any ideas on how i can stop that from happening.
Check if they are actually even bent. On my bike the bar seems misaligned after almost every crash, but all i have to do is whack it to right direction using a lamp post or tree and it's good to go again. Sometimes the bar is aligned on the way to a one. My theory is that the rubber washers or just the slack in the connection gives yet the bar doesn't reset itself so it only needs a little whack to make it settle again.
Did you not see the picture? The bolts were definetly bent
