JHNguyen89
Any tips on finding an oil leak?
I purchased an 08 TXC 250 just a couple of weeks ago. Upon receiving it, I had issues removing the drain plug as it was cross threaded. I finally pulled it out and chased the threads and purchased new drain plugs from 7602 racing. After two rides, I noticed the oil level seemed a bit low. I drained the oil and measured 1 L of oil in which I had just put in 1.6 L 2 rides before. I've stored my bike in my garage and have not seen any drops of oil on the floor. However, I do notice some oily areas on the bike.
I expected the bottom drain bolt that had damaged threads was where the leaking is coming from, but it doesn't seem to be that way as I'm not seeing any drops on the floor.
Not sure if this is normal or if I'm just making some newbie mistake as I'm still very much of a beginner. I hope the photos help.
I will be adding new oil tomorrow AM and am curious if anyone has tips to find what seems to be a slow leak?
