Fuel tank transfer
Husq-a-daygo
I swapped back tank set up from the IMS back to the stock configuration recently. I've been having issues with the fuel transfer to the fuel pump tank. Obviously its a breather issue. I replaced the single fuel line down to the .5 gal fuel tank, confirmed flow is good through both petcocks. I kept the T modification for the breather from the IMS tank and have tried both keeping the 1/4" line plugged and open with the same results. Fuel wont transfer to the lower tank unless I remove the gas cap. I pulled off the 1/4" breather line coming off the top tank on the right side of the bike (exhaust side) and the fuel will then transfer as well. I experimented with +/- pressure into the breather one way valve and it appears not to open either way. Is that supposed to work this way??? I hesitate to remove the valve as I do not want gas sloshing out from the top of the tank on whoops etc. Do I need to replace this part?
Any insight from fellow TE511 owners is appreciated...
