bensl
thanks, but i am referring to a 610 which does not have the hydraulic clutch.
i found this online
"With a properly adjusted clutch, there should be a minimum of 1/8" to a maximum of 3/8" free play between the end of the lever and the perch, with the lever at a released state. If the clutch lever is tight against the perch without any noticeable play within the cable's pull from a released position, the cable needs adjusted to allow slack in the cable which will allow the clutch full engagement. A clutch cable that's too tight could easily cause a clutch to slip since the cable will not allow the clutch to fully engage, and this should be addressed before continuing."
so if neutral is difficult, the clutch is not engaging properly so the cable needs to be loosened?
i found this online
