toolguy1
We no longer accept MY11 TE449 ecu's. I have not been able to re-flash an ecu from this year.
Uh oh!........this doesn't sound good for me.
I do the same kind of riding . The bottom end tuning does not effect the top end so tuning for big power on top is ok. I will review and make note of my curent settings and get them to you. The default JD setting did not work good for me at all. I have dyno tuned setings for my 12 TE 511Basically the recommended settings from the JD tuner box.
The riding I do is most technical tight single trail so I'm more concerned with torque and preventing flame outs than big power. My engine does occasionally still cut out while jumping a big log and I can't say if it's me or the bike, since this is the first bike I've ridden in this type of terrain.
http://www.cafehusky.com/threads/really-good-jd-settings-for-2012-te-511-here.34492/Basically the recommended settings from the JD tuner box.
Is your bike faster on the top end ? Is the map only "jetting" ?Rode my SMR with the updated mapping, it's like a new bike! JD Tuner is in bypass mode and I'm not sure it'll get used too much any more...
mine broke clean and was able to do a push up 2 weeks later.
cracked my shoulderblade and tore out a nail bed on broken glass at the bottom of a hillclimb on the same crash. My girlfriend at the time thought I was good enough to fool around when she brought me home from the hospital , she was wrong. She was a crazy Porterican .You shattered it , that's ugly![]()
I've only rode mine once (100 mile loop) with the map #3 and the JD disconnected. No flameouts in sections I normally got them with the JD (tight twisties). Bottom felt good, not nervous like before in the twisties. Didn't notice much difference on top, maybe a smidge more. Did use a smidge more fuel.Is your bike faster on the top end ? Is the map only "jetting" ?
Sounds like the remap has a much improved fuel delivery. My JD settings sounds very similar in performance. On the JD a half position one way or the other can mean a big difference in thoughs flame out sections and top end power. I was fighting the low speed setings for a while with my JD and now it seems very good now . Sound like the remap isn't a ignition upgrade but a good way to make your bike run with the smog off and a high flow muffler.I've only rode mine once (100 mile loop) with the map #3 and the JD disconnected. No flameouts in sections I normally got them with the JD (tight twisties). Bottom felt good, not nervous like before in the twisties. Didn't notice much difference on top, maybe a smidge more. Did use a smidge more fuel.
Get map#3 instead.whats a JD tuner and where can i get one ?
