Yeah, a crawler gear is a nice addition, but as an aftermarket solution it would have been expensive as it would have required a new gearbox input shaft, first being integral with the shaft.I could live with the option of a slightly higher 5th and 6th, but it's not gonna happen now... As it stands dropping into the optimum rpm means short shifting, because if I use all the over-rev (the old motor is still pretty fit) I pretty much have to shift up
two gears to hit the sweet part of the torque curve.
Many engine components were shared between the 250 - 510, so the close ratios that were necessary for the tiddlers were overkill imo for the bigger bikes. No big bore thumper expressly requires six cogs
that closely spaced - unless it has serious power delivery issues and we all know that wasn't the case here!
The top few percent of competition riders may be able to exploit
optimally narrow ratios (and their teams would be minded to e.g. change final drive ratios between stages), but for most real world customers too-narrow gaps can cause a number of problems:
1) Every time a rider has to shift he (or she) loses drive, plus there is always the possibility of losing traction or otherwise unsettling the bike, either under acceleration or braking. There's always the opportunity for a missed shift too. No needless shifts = less risk. For free.
2) More shifts means more fatigue for both rider and machine. More distraction too.
3) Many bikes are bought expressly because they can be plated. Not everyone races! We don't all have trailers and anyway, a bit of tarmac is often unavoidable when exploring or jumping from trail to trail (or when seeking out some lunch!). Having to gear low to keep a bike useable on dirt turns even the shortest asphalt stretch into a miserable experience - machine and rider fatigue is increased and fuel range goes through the floor. We supposedly do this stuff for fun!
Consider also the supermoto guys. How are you supposed to gear for the flat out dash down the straight
and the dusty, walking speed hairpin that leads to the double? Bog. Crash.
Sorry about the rant, but selling unmodified competition bikes as plateable / leisure is just lazy and I don't think that it does anything to increase participation levels in offroad. Obviously a lot of manufacturers are more or less guilty here and I'd like to see all of them applying a bit more "customer focus". The factory could always offer a close ratio cluster in the "special parts" catalogue. Side loading cassettes would be nice too.
Rant over - I promise!
