Chain Snapped.
While your chain is off, pop your front sprocket off and put some heavy grease on the countershaft splines. Not oil, not wd40, not tri-flow, heavy grease. Do that every time you put a tire on it.
I know that is a popular practice to help with spline wear. I think it is when we are talking about a fairly dirt free environment.
When things get dirty (IMO) the grease holds the dirt and forms a mixture very similar to valve grinding paste.
On heavy equipment I have experienced less pin and bushing wear by leaving the grease out of unsealed pivot joints that are always in the dirt.
I keep everything greased and oiled, but I clean and relube after every dirty ride. If you ride real dusty stuff,
Maybe keep it dry, wet, muddy (it's like sand paper) good waterproof grease keeps it out. Dry metal wears out
Faster than lubricated metal, but you have to keep up with it.
Popping the front sprocket off, is it simply a case of removing the circlip and it will slide off the countershaft?
That's an excellent point.
Yes.
