sailah
Was waiting on parts to put the bike back together and needed a chain guide as the stock plastic thing had destructed long ago. I was ordering parts from Halls and ZipTy today and thought about the TM Design Works but thought I could do better. So I mocked up a model basically duplicating the Husky chain guide but made for 3/16" 6061 aluminum.
I cut the parts out on the waterjet and they lined up perfect the first time. I won't lie and say I didn't print out a couple full size parts on the laser printer to check alignment though haha
You can see where I added a plate and TIG welded it to the bottom. I'm redoing that. So I extended the bottom of the guide the thickness of the plate in the Inventor model so the welds will be on the bottom. But the trial version did bolt right up to the swingarm just like factory and holds the stock plastic guide just like the original.
I will probably end up powdercoating it to match the swingarm although I might anodize it as I have a run of axle wrenches I need to get hardcoated. But I like powdercoating, it's easy.
