motomanic
Hi, a JD Tuner arrived from Motosportz and at the same time as fitting it I also wanted to change front and rear sprockets to 14/53. Started the sprockets 1st, and watched the U Tube Tutorial in Italian, how to change the front. It was during this that it was discovered that the bottom shock and frame/swinging arm bearing are shot and need replacing. Expensive?
The shock looks self explanatory, remove it as the top bolt looks accessable with the side panels removed.
How do you remove the frame bearing, any special tools required?
Is this a common problem, its water ingress,probably from jet washing, but the UK tends to lend its self towards muddy riding.
Secondly I fitted the tuner but couldn't ride it due to the bearing issue, great bit of kit, i see it comes programmed for the Akro that comes with the 449/511. Is there any better adjustments to be had?
Thanks in advance for any help coming my way.
